跳转到主内容
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
How do you take out a affected analog stick from the motherboard?
I have ruled out cleaning. question, how to Remove a affected analog stick from its motherboard?
DualShock 4 CHU-ZCT2U
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
In order to replace a single analog stick you will need to have the ability and tools needed to unsolder and solder in a new stick. They are not meant to be individually replaced. The easiest way to replace a faulty analog stick is to replace the entire motherboard per the DualShock 4 CHU-ZCT2U Motherboard Replacement guide. If you do have the tools to solder in a new analog stick like the ElecGear analog stick replacement, if you do this it is recommended that you replace both sticks at the same time due to one failing there is potential for the other to need replacing soon.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
user123 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 67
