跳转到主内容
The HP Pavilion x360 14 (specifically the 14-dw1010wm) is a versatile 2-in-1 laptop with a 360º-rotating 14-inch multitouch display, an 11th-gen Intel processor, and Intel Iris Xe Graphics. It comes with DDR4 RAM, an NVMe M.2 SSD, and 3-cell, 43 Wh Li-ion polymer battery.
Screen replacement for x360
Hey everyone hope you are having a good day, has anyone ever replaced a screen on a HP Pavilion x360 ? If you could please show me a video or link a replacement that would be more than great!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Hi @brandontunnell,
Please confirm the full model number of your laptop as shown on the product info label on the bottom of the laptop?
完成的
hp pavilion x360 14dw1013tu
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @brandontunnell
Here's the maintenance and service guide taken from this support webpage for the x360 14dw1000 series laptops.
Go to p.51 to view the procedure to remove the display assembly. On p.53 the LCD panel is being removed.
Also on p.53 you'll find the HP part numbers for the LCD panels that can be used. Usually the part number is somewhere on the back of the panel if you wish to verify which one you have now. Search online for the part number only to find suppliers that suit you best.
p.s. If you post the product number of the laptop (also on the info label) I may be able to find the part number for the screen so that you can order it before having to disassemble the laptop to find out what it is.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Brandon Tunnell 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 52
总计 643
