跳转到主内容
Xbox Series X 是微软公司次时代4K游戏主机。2020年11月10日,Xbox Series X与其配套主机Xbox Series S一起发布。
20 个问题 查看全部
My Xbox Series X will not power on consistently
I recently purchased a Series X through an online auction, and the console won't start.
When I press the power button, the power button lights up for a moment and then goes out, and the console does not start.
I replaced the power supply unit, and the power came back on for about a minute, but the same issue occurred again.
Which part is giving me this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Hey there, I edited your question a little bit for clarity. Just for clarification, were you ever able to boot your Xbox to the home page, or play any games?
完成的
Hi jacob !
Thank you for your comment. My English is bad so I hope I can convey it well.
No, I couldn't play games because it wouldn't start; the power would turn off before I could even get to the home screen.
When I replaced the power supply unit and it started up for about a minute, it worked until I got to the user selection screen.
完成的
Not a problem! I'm wondering if it could be an issue with your device's cooling. When you try to boot the device on are you able to hear the cooling fan kick on?
完成的
thank you!
The cooling fan isn't working right now. Again, the fan was working right after I replaced the power supply unit. However, now the fans don't work and the logo screen doesn't appear. Looks like the power will turn off before that happens.
完成的
Anyway, I'll try replacing the cooling grease this weekend.
完成的
添加一条评论
2个答案
已选择的解决方案
Did you ever figure out what the issue was?
Mine is doing the EXACT same thing.
Powers up with the light on, fan spins up then off and shortly after that the console shuts off.
I bought a replacement power supply but dunno if that is the issue, haven't taken it apart yet.
Cheers
这个答案有帮助吗?
得分 0
1条评论:
Hi
In the end, I'm left with an Xbox that doesn't work and I don't know why.
I ended up buying another one so I'm playing with that one now.
完成的
添加一条评论
I replaced the thermal paste.
I assembled it and tested it, but the situation remained the same.
As shown in the video, I turned on only the motherboard (logic board), but it's the same, so this may be the cause.
There was a similar repair video on YouTube, but I don't have any more technical skills, so I'll take a break for now.
thank you
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ソウイチロウ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 337
