跳转到主内容
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
How do I replace the Keyboard backlight on a2159 MacBook Pro
I can’t find a video on it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Are you sure you need a need keyboard backlight?
Finding the backlight plate for this series is not easy! Apple reduced its service parts at this point you’ll need to find a parts junker to reuse it or if you has a liquid spill I think you’ll find just getting the full uppercase assembly MacBook Pro 13" (A2159, 2019) Upper Case Assembly
Replace an upper case, keyboard, and battery compatible with a 2019 model A2159 MacBook Pro 13 inch laptop with two Thunderbolt Ports.图片
产品
$149.99
这个答案有帮助吗?
得分 0
3条评论:
I mean the cable
完成的
But either way I found all of the parts for it, and it’s not that expensive
完成的
@ola48955 - Well that’s a different kettle of fish😊
Here’s the needed part Keyboard Flex Cable
The process is the same as taking out the logic board following this guide MacBook Pro 13" Touch Bar 2019 Logic board Replacement
完成的
添加一条评论
A2179 keyboard light is not detachable , All butterfly keyboard light is embodied with the keyboard which mean you have to change the keyboard
这个答案有帮助吗?
得分 0
2条评论:
No I mean the cable
完成的
its a flex besie the battery
完成的
添加一条评论
添加你的答案
Ola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 198
