Sunbeam PAC-259 Queen size dual Heating blanket Style G85KQ
Everything looks good, continuity good through out both sides, in both controller in preheat mode, i read 3.3 Vdc running through.... but no heat whatsoever.
Fuses good..... what should i look for to test ?
Thank you...
André,
-striving to fix everything i can... and will learn
6条评论
@andrefontaine Do you know where the heating elements are located? Those would be the next things I would check.
Edit: I think sone of those wires might be directly hooked to the heating elements. Can you test across those with your meter in ohms mode and tell me what you get?
由 Andrew S 完成的
added a 2nd picture, there are 4 white wires. 2 on each side of the white box. each side being a side of the bed ( queen size, 2 individual controllers). So one loop has actually 2 indidual wires. Each has continuity. i get 3.3Vdc ( + - ) when preheating.
where do you want me to measure the resistance ? ( + + ) ( - - ) ( + - ) ? i think that each loop is an actual heating element.
由 andre fontaine 完成的
@andrefontaine Measure each heating element with the resistance mode on your multimeter while the device is unplugged drom the wall outlet.
由 Andrew S 完成的
( + + ) = 14.9 ohms and same value for ( - - ) as identified on the second pictire.
What about the (+ -) resistance on both pairs?
由 honakrisi 完成的
显示更多的1条评论
