跳转到主内容
The Lenovo 300e is a convertible laptop and versatile learning tool that is powered by Intel. This device comes with a charger and 3 built-in USB ports.
7 个问题 查看全部
Has anyone done a 300e Keyboard replacement?
Hey guys, Our school district has about 400 of these guys and I've seen a couple with bad keyboards. I'm guessing it's a bad ribbon cable but it's impossible to get to it as the keyboard is riveted to the frame. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @clarareid
If it is only a few keys on the keyboard that are the problem it may be the key itself and not the keyboard per se.
There are suppliers¹ online that supply the keys for a lot of different models. You could always contact them first or maybe just get one set of replacements to see if replacing the keys resolved the problem.
¹Supplier example only - there are other suppliers, search online for laptop key replacement.
这个答案有帮助吗?
得分 1
1条评论:
I have about 400 of these devices in my care. In an attempt to see what's up, I did take apart one of the keyboards completely. I suspect it is a fault in the ribbon where it joins with the keyboard (not the other end). Looks like the only real fix is to order a replacement Upper Case like @Ottobunnycoder mentioned.
完成的
添加一条评论
You will probably have to end up replacing the whole upper case. If the whole keyboard isn't working, it could possable be the cable. If only a few keys aren't it would probably be a keyboard issue, or a keycap.
这个答案有帮助吗?
得分 0
1条评论:
I have this problem as well in a similar fashion - for a school. I keep finding that N & B keys fail first. Are you finding this? Have you found any solutions with your keyboard problem? Thanks!
完成的
添加一条评论
添加你的答案
Jacob Creasy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 78
