跳转到主内容
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
Can the digitizer cable in the display be repaired/replaced?
When opening the computer to replace the battery, I ended up damaging the digitizer cable on the LCD screen. Any way this can be fixed or replaced?
Screen works perfectly, lost the touch screen functionality though :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I'm so sorry this happend! It looks as if the display cable is part of the display. Try pulling gently up on it, and if it doesn't work, I think you will need a new display. You might be able to find a cable somewere and solder it, but that would be very hard, if possable.
这个答案有帮助吗?
得分 1
2条评论:
I appreciate your suggestions. Replacing it does seem like the best option, as attempting to solder without the right equipment can be very challenging. Unfortunately, I don't have access to a microscope. I'll look into getting a replacement display and hope that resolves the issue. Thanks again for your help!
完成的
@soryn no problem! Glad I could help.
完成的
添加一条评论
添加你的答案
Soryn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 139
