跳转到主内容
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
113 个问题 查看全部
does the A2159 Keyboard Cable power the keyboard
A year ago my little brother cover my macbook with water. I opened it up got all the water out but 3 months ago I tried to use the keyboard and it was not working. so I'm thinking if I tried to change the keyboard Cable power maybe the keyboard will turn. (I tried everything else and It worked just fine only the keyboard)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
No, it does not power it. The Touch ID represents the power switch. but when you tap the keyboard when you MacBook air (A2179) is shutdown it will power up the system
这个答案有帮助吗?
得分 0
1条评论:
To add to Alexis answer - Electronics and Water don’t mix well! The keyboard it’s self is likely damaged from corrosion. You likely need a new keyboard assembly or the full uppercase (which is what I would do) here’s the needed part MacBook Pro 13" (A2159, 2019) Upper Case Assembly it’s expensive as it also has a new battery besides the keyboard.
完成的
添加一条评论
添加你的答案
Ola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 22
