跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Switch Won't Turn On (Unpatched V1)
I'll get the unpatched part out of the way first. The serial starts with XAJ7003 which I believe is unpatched hardware that can be more easily modded. I don't intend to do this but it may be that the previous owner tried and bricked the console.
I bought a used "junk" switch from Japan and it failed test #1 - it doesn't turn on. No charging/battery icon and no signs of life. I did a bunch of tests listed below, and any parts or tools used are verified working from my store bought and still working fine Switch.
  1. Plug it in to charge for a few hours (official Switch charger to wall and USB to PC)
  2. Use a fully charged battery from a working Switch
  3. Hold the power button for 20s and then press again
  4. Open up and clean all ribbon cables and re-apply thermal paste
  5. Try to power on while docked in case the screen wasn't working
  6. Press the power button directly on the board/ribbon
  7. Test continuity on various things with multimeter (I don't really know what I'm doing here but everything I tested had continuity)
If I plug it into my computer it's listed in Device Manager as APX (!). Not sure if that means anything.
The internals were all very clean and beautiful other than a tiny bit of dust, which hopefully suggests nobody has opened it up to tinker before me.
I'm hoping someone could give me advice on what to try next.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Me and u gang me and u😔
完成的
@jamaalkay check if its in rcm by downloading the software in the link i provided and connect the switch to the pc
完成的
添加一条评论
1个答案
download tegrarcm from here https://github.com/eliboa/TegraRcmGUI/re..., connect the switch to the pc to see if it shows that its in rcm mode
这个答案有帮助吗?
得分 0
2条评论:
No luck. Windows plays the device detected sound but TegraRcmGUI says "No RCM device detected".
However, after having it charge for a bit I did notice there's a warm spot on the top of the device between the volume buttons and the exhaust.
完成的
@fliggle_slaps if windows makes the connected sound then its possibly switched on. can you take the back casing and metal shield off
完成的
添加一条评论
添加你的答案
Fliggle_Slaps 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 33
总计 229
