跳转到主内容
加入维修社区 - 创建账户
Repair information for the HP Pavilion dv7-6163us laptop. It was released in 2008.
Shuts off unless it's plugged in but says the battery is fully charged
I bought a new battery for this a couple months ago and it worked fine until a few weeks ago. Now it can only stay powered on if it's plugged in despite the battery saying it's fully charged. I never had any issues with this until now, I didn't leave it on the charger all the time, and did nothing different from the months prior.
I tried taking the battery out and restarting it, I dusted the ports (but can't get the case off due to 3 stubborn and now stripped screws...) I don't know what else to do or how this even happened. Any other ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Does it fade out when it shuts itself off, does it shut down, or does it just cut out?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @pandabear4087
Create a battery report to check the charge status of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value.
For a good, new battery, the values should be nearly the same.
If the Full Charge Capacity value is <30% of the Design Capacity then the battery maybe cannot handle the load and it is failing or has failed.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Panda bear 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 113
