跳转到主内容
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
140 个问题 查看全部
power button stopped working rest of keyboard and trackpad are fine
The powerbutton of my macbook 12" early 2016 stopped working. The weird thing is that i turned the mac off using the power button. Than it just turned off. Next day its not working, need to start the mac using the power cable.
That being said, 4 months ago ive replaced the batteries, while doing so the keyboard also stopped working, turned out the internal flat cable wasnt completely connected, ive recornnected it and all was fine.
Just to be sure it isnt the cable, ive disconnected it and reconnected it, im certain its in the connector correctly. Also ive checked all the buttons, and literally the power button is the only one not working. Caps also illuminates correctly.
Im baffeld. If someone has an answer id be gratefull, thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The Power button is no different than the other keyboard keys! So the discrete button can fail beyond the keyboard connection you had faced before.
Here the switch discretely connects to the logic board via the ribbon cable so is there any damage to the ribbon cable along it as well at the connection point? It’s also possible you had a liquid spill which got into switch contacts.
I don’t remember if the Apple Bluetooth keyboard power button will work here. That might be a possibility to at least help isolate the problem down.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rene 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 18
