Power stereeng not working
Check the fuse located under the dash for your electronic power steering module. If it's okay, then check the harnesses for the module itself for bad connections or corrosion on the terminals. If there are no bad connections, you'll have replace the EPS module itself more than likely.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 58
