跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy S II 是一款由三星电子设计、开发和销售的智能手机,搭载 Android 2.3 "Gingerbread" 系统。
Why do callers hear an echo during phone calls?
Hi!
Everyone who calls me says they can hear a bad echo of their voice as they speak, but everything sounds normal on my end.
I looked on some forums and some users blame the phone case for the echo. I took the case off and the echo didn't go away. Other users have tried sending their phone in for repairs and/or complete a factory reset with no luck. Is there anything else I can try?
Thanks!
Wendy
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 103
18条评论
hey thanx so much for that tip ...will give it a try...im reluctant to send it in for repair...have u tried that?
完成的
I also have the same problem but if i turn off the loudspeaker there was no echo.
完成的
I have the same problem and swapped sim cards with my wife. now she has the problem. swapping back.
完成的
Tapped by Mi6
完成的
Pls help me solve the echo problem with my techno camon 11
完成的
显示更多的13条评论
添加一条评论
30个答案
已选择的解决方案
i have the galaxy3 and it was doing the same thing!! Drove everyone insane but me because i didn't hear anything! I went into call history log, hit menu, went to call settings, additional settings, and unclicked the Noise Reduction selection and it fixed the issue. hope this helps!
这个答案有帮助吗?
得分 26
25条评论:
thank you man!
I'm using Samsong S5 and encountered the same problem. I was getting lots of commets from my friends and family about the echo, and your simple commet solved it!
完成的
seems to have fixed mine too! Thanks! I have the galaxy3 as well'
完成的
how do you get to your call history log?
完成的
I finally solved the problem with my s4. Bought a case with an open bottom and top. Turned notice cancellation on.
完成的
Fixed it for me. Thank you very much. Samsung Galaxy S2
完成的
显示更多的20条评论
添加一条评论
Hi Wendy
I have the same problem.
It seems to be some clever trick that Samsung have included to try and reduce ambient noise on incoming calls, and have basically made it so that on incoming calls the speaker is on very quietly, which makes a loop and causes an echo for the caller.
When you have answered the call, if you press the menu button, and press "noise reduction off" if will fix the echo problem for that call. unfortunately i haven't figured out a way to turn it off permanently yet!
Simon
这个答案有帮助吗?
得分 6
4条评论:
Ironic that the noise cancellation feature causes noise!
完成的
I had the same problem on my Galaxy S II with people hearing themselves talk so I went into my settings/call/additional settings & unchecked the noise suppression option & made a phone call & WooHoo it worked! Thank you Simon!
Ramona
完成的
When In coming and out going calls, you'll have a display that comes up, press the speaker 🔊 button on.
完成的
Make sure wifi calling is turned off
完成的
添加一条评论
I finnaly found that the problem became from the extra shell case i used.
so avoid any extra shell case to make a test.
That's the solution a found whith mine. I think that the extra case (not a samsumg case) genarate echo because of the 2 microphones on the top and the bottom, I don't know why but I think that the case act like a echo box.
这个答案有帮助吗?
得分 4
1条评论:
I bought a case with an open bottom and top. Turned noise cancellation on. Solved it for my s4.
完成的
添加一条评论
This is a problem with most phones. Just pick any manufacturer and type their name in google and then put "echo problem" after it, without the quotes. You will see tons of phones have the same problem.
The problem is they use the phone case as a type of speaker box. They allow the back of the speaker to "breath" into the case so that it can produce bass. That makes the speaker sound better and easier to understand people talking.
If you have a noise cancellation mic at the top of the phone, you can usually put a piece of tape over it and that will help.
A better fix is to take the screws out of the back of the phone (if you are brave) and putt something like a piece of closed-cell foam near the bottom of the phone where the regular mic is. The idea is to keep the sound from the speaker from traveling into the regular mic. If you put the foam too close to the speaker, the callers will be a little hard to understand because their voice will have no bass and it will make the phone sound really cheap.
But it is a lot easier to put the tape over the top microphone. ;-)
这个答案有帮助吗?
得分 4
8条评论:
Some of the galaxy phones only allow you to turn off noise reduction on a per call basis. So you may have to do that every time you make a call. Depends on the phone. Are any of you running into this problem?
One of the galaxy phones I had also severely reduced the volume when the noise reduction was turned off. Have any of you noticed this?
完成的
Most definitely for my Samsung Galaxy S4 it was the case and the top microphone. Put some tape on the top microphone and put the case back on and the echo is gone!
完成的
Hi Susan Yoder. If you have a second mic (should be small hole at the top of the phone) try tape over the hole. If not, if you go to youtube and search for “cell phone echo problem fixpro256″ (probably don’t need the quotes) there is a better explanation of how to fix the echo.
完成的
I put tape on the second mic at the top of the phone and it worked. Been driving me crazy with complaints from ppl I called or called me. Got to the point where I hated my phone. Now it's time to learn to love it again. Just fixed it r on I got, so we shall see.
完成的
Different versions of the phone/firmware/OS will have the noise reduction option implemented in different ways. With the S2 Verizon phone I had, it would only work for one call at a time. On the S3s Verizon phone I have the setting stays the way you set it even if you reboot.
If I remember right, people say they can't hear me as well when noise reduction is turned off.
You can probably get rid of the echo my just turning the volume down. That way the built-in earpiece isn't as likely to be picked up by the mic. Try that and let us know if it works.
完成的
显示更多的3条评论
添加一条评论
if it is in a protective case take it out mine works fine after this.
it is very annoying when it does echo
这个答案有帮助吗?
得分 4
3条评论:
Installed my original open top and bottom protective case and the problem was resolved :) :)
完成的
My husband has the Samsung Galaxy Note 3, and the echo (that his callers would hear, of their own voices) was awful and distracting.
Just now, I read about the case sometimes being the issue. I called him, got the echo, and had him remove his case.
Voila! Problem 100% solved!!
No idea what brand his case is, but removing it fixed the issue.
Thanks, everyone, for sharing your issues!
完成的
I tried all of the above from turning off noise reduction to inserting the cloth,nothing worked until I removed the case. [THIS CORRECTED THE PROBLEM.]
完成的
添加一条评论
something you can try.
1) make sure the carrier have the hardware you're using is registered to you and not your old phone.
2) use a headset w/ mic and make a call to see if there's an echo.
-if this is yes, it could be your carrier tower OR your hardware
- if no, then it's your hardware.
3) use a speaker phone and see if there's an echo.
if the problem still keep up, or been fixed, let us know! ^_^
这个答案有帮助吗?
得分 3
1条评论:
Which hardware. Tell that.
完成的
添加一条评论
clean out the tiny holes top and bottom of phone.samsung Galaxy 2. worked for me.try using a magnifying glass.
这个答案有帮助吗?
得分 1
4条评论:
This worked for me too. The microphone hole in the outer case was partially blocked after I repaired the case with glue!
完成的
I tried some of your suggetions but not a single one works.. So i looked at my samsung S4 which has the echo problm... and i noticed that there is some dust in mic hole... i cleared it with a needle and its really works now with no echo for caller or for me ...
完成的
I have a Samsung A21s. Followed advice above about turning off wifi calling and it worked!! No more echo for people I am calling.
完成的
My phone is still echo
完成的
添加一条评论
I have a brand new S5 neo giving me the same problem. The only way I could get rid of the echo on the other end was to turn on the speaker phone, or plug in a headset. I tried just about everything, even Samsung's technical services without much luck, other than sending it down east for an evaluation. I never could find a noise reduction option on my phone setup, but, I did have a "hearing aid" assist thing which I turned off .... miraculously, it worked and all is well. I figured it would be something simple and it was. Good luck.
这个答案有帮助吗?
得分 1
2条评论:
Go into your Settings ...... Scroll down to "Accessibility". Scroll down to "Hearing" and give it a tap. Make sure the hearing aid switch is turned "off". ....... enjoy your phone.
完成的
I also had the echo problem with the Samsung Galaxy S5 Neo. Thanks to this solution and turning off the hearing aid option under "Accessibility" in "Settings", it appears to have solved the echo problem. Thanks sooooooo much!!!
完成的
添加一条评论
This has to do with your cell phone provider, the location of the cell tower, where you are located in relation to the cell towers, and objects in the way that block or reflect the signal. Try going to a different room in your house or to a different spot outside. If the people your talking to still hear a echo, then you gotta switch carriers if you absolutely love your cell phone.
Alternatively, you can read reviews of best cell phones with no echo and switch phones if you absolutely love your carrier.
这个答案有帮助吗?
得分 0
5条评论:
Not in my experience. Same phone, same location, same carrier. One phone has the problem, the other doesn't. In my case it's the S5
完成的
I disagree. I have 4 sgs4 in my hose and an sgs5 and only one has this issue. My husbands phone is the only one that does this inn the same locations as the rest and it is one of the S4s.
完成的
The S5 that has the echo does it with or without a case. Also tried the remedy of changing background noise canceling as c well as putting a piece of foam inside the phone over the microphone. Still does it. I am thinking of purchasing a new microphone to see if that works.
完成的
Sorry meant to say S4 ^
完成的
I decide to rethink this issue after reading about the new s7 not being as water proof as claimed... long story short go back to the basic mechanics of the phone. I have replaced the screen a few times so I've been inside and know what's what. I have also seen videos on placing a piece of business card or foam over the microphone location. I tried all of this and nothing did the trick. I have ordered (and it's very inexpensive) the "charging port and mic flex cable dock" because I think this is where the problem really is. It's a fragile piece and if the phone is dropped or dust or even humidity gets in it - it could cause the issue with echo in the mic. It should arrive in a couple of days and I'll let you know if it works. The price on ebay for the S4 is $5- $7. Also, if it still does it then it is the speaker unit. Also about $5 lol
完成的
添加一条评论
Most likely its the rubber coating over the mic located inside the case on the bottom of the phone obviously.
Open up your phone and make sure to push the rubber in deep in to the case. There's a small hole in the rubber and in the back casing and they should align perfectly. When the phone is assembled you should not be seeing any of the rubber from the mic hole.
这个答案有帮助吗?
得分 0
添加一条评论
Callers to my Galaxy II get the echo. Only after answering tap the bottom left menu; then put noise reduction to off. This works, but doesn't always stay off with future calls. My sales person clued me in on the solution fix...said it happens when a protector case is used, but haven't tried receiving a call with it off yet to see. I don't like to carry it in my pocket with no protection even if that works.
这个答案有帮助吗?
得分 0
添加一条评论
I am having the same problem with the international version of the S4 active. As with lots of others the problem does not exist with the backcover removed or when using phonespeaker or headset.
But I also found that there is also no echo, when just removing the microSD card and putting back on the cover and not using phonespeaker or headset.
It seems, that there is some kind of electrical interference as long as the SD is installed or some kind of incompatibility with SD cards? I just found this, hence did not try yet with diffeent vendors from SD cards or putting a "dummy" in it, just to see, if the issue also exists, if there is no actual electrical contact.
I also heard from other unoffical sources, that Samsung is planning to get this fixed with a new firmware?
Cheers,
Timo
这个答案有帮助吗?
得分 0
添加一条评论
Yes, the callers complane so much to hear a strong echo on my Galaxy s4 active. I asked around and found a good technician that open it up and found a little plastic bent close to the mic. He put it in its place and all is fine.
这个答案有帮助吗?
得分 0
添加一条评论
remove S4 back cover. and cover speaker with light tissue. the problem will solevd.
else, to go for any maintenance place and let him to replce back speaker.
这个答案有帮助吗?
得分 0
添加一条评论
ECHO ON PHONE
Ever since contracting into my Acer Liquid 3 phone, I have echo problems. First of all I cannot get a network signal where I live, but I am able to use the phone as I have WiFi at home. However when using the WiFi there is an echo which only the person who receives my call hears (I don't hear it). Incidentally when using the network away from the house calls do not incur echos, so the problem is only when in a WiFi area. After weeks of frustration and experimenting with all sorts of ways to rectify the situation (my network local shop stated they had never heard anyone have an echo on their phone and I was unique!!!!!!) I have found that if I wear the earplugs supplied with the phone or any other earplugs this actually works. The person to whom I am speaking does not hear an echo! I know it is not the ideal way to conduct a telephone conversation but belief me I find it wonderful that there is no echo, as do the people I am speaking to, and also I did find it very hard to hear and this means people are speaking directly into your ear and the volume has greatly improved. When on Speakerphone the echo was unbearable, so I never use it. Don't need to as the earphones are great. I trust that this helps someone to solve their own problems. Worth a try anyway. Good Luck.
这个答案有帮助吗?
得分 0
添加一条评论
I took the plastic gel case (which came with the new phone) off my Samsung Galaxy S4 and it solved the problem immediately. Result!
这个答案有帮助吗?
得分 0
1条评论:
This worked for me too. By simply removing the phone case. Thanks so much.
完成的
添加一条评论
A few things you can try to narrow in on the cause of the problem....
Turn your volume down. The sound from the speaker in the earpiece sometimes makes it to the microphone thru the internals of the phone. Turning the volume down will tell you if this is the problem. If it is, this is a possible fix for it....http://youtu.be/FkcxzmCPFWw
Take the case off. Sometimes the sound from the speaker in the earpiece travels thru the case and reaches the microphone.
Turn off noise cancellation.
Keep track of when it does and does not happen (after reboot, certain callers, 3g vs 4g, cell tower...)
Echo should not happen. Sometimes it is a physical problem with the phone. Sometimes it is a bug in the programming of the phone. If you can't resolve it and you wan't out of your contract, write a letter to the FCC. That quickly got me out of mine with T-mobile and 3 phones (all samsung S3) that had echo problems.
I had a friend on T-Mobile with an older S3 with the echo problem. I fixed it using this video....http://youtu.be/FkcxzmCPFWw
这个答案有帮助吗?
得分 0
添加一条评论
Hey guys its a very stupid idea..but try it..it worked PR fectly for me....
1st of all remove all the back covera on ur phone.. And see where the mic is located..bith the primary as well as the secondary...as u find them..just try and suck the mics with a bit of pressure...it solved my problem..as my rubber cover was a bit loose frm inside..sucking it created a pressure of air..which pulled the cover more inside..hence my echo problem was solved...without opening my mobile phone...try ur luck guys..
这个答案有帮助吗?
得分 0
添加一条评论
You might want do disable talkback. It's an app for disabled people. Just drag down the black bar on the top. Go to settings (the wheel), then go to more (at least on my s3 it is like this), after this you go to applicationmanager. You can disable/remove talkback. Let me know if it worked
这个答案有帮助吗?
得分 0
添加一条评论
Turn down your volume. They can hear themselves because your car audio is too loud. If the car audio is just as loud as you are, how would the person on the other end of the phone not hear themselves? Lol.
这个答案有帮助吗?
得分 0
添加一条评论
Is it occurs occasionally or all the time? Maybe your phone has a weak signal, when you answer the phone. You can try to reboot your phone, or move to a place which has a strong signal. If it still doesn't work, maybe something with the mic or antenna. You should check it carefully.
这个答案有帮助吗?
得分 0
添加一条评论
I feel foolish ... after having tried everything, but really everything conceivable but could not use WhatsApp, Viber etc. when using the Speaker phone. Normal phone calls were ok.
I finally looked for the small mike hole on top - after all, many of you recommend to cover it with a small piece of plastic - and then found that I had not properly removed the protective (almost invisible) plastic cover that the supplier had placed there to protect before shipment...
I removed it and now have a S4 the way Samsung designed it. Works perfectly. For the first time in a long time!
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem ,I believe that the microphone is ultra sensitive so when you have the mic close to you when speaking the other party listening
Receives an annoying echo . so I fooled around with it and had the microphone far away from me when speaking no echo. I'm about 6 feet ,I had my ear buds hanging from my ear to my waist,every one says they can hear me loud and clear ,maby that will work for you.
这个答案有帮助吗?
得分 0
添加一条评论
I spoke with Verizon support and was told that if the headset is connected to the phone with a cord, there can be a resonance created that will cause an echo. The solution was to go wireless. When I tried a wireless /bluetooth headset the echo was not present.
这个答案有帮助吗?
得分 0
添加一条评论
When you go to make a call click on settings and check if the hearing aid mode is on. Or TTY. If they are on turn them off. That was the problem with my Samsung.
这个答案有帮助吗?
得分 0
添加一条评论
i had the same problems too -- it has echo or bad feedback when your phone is too loud (i mean when you put in a loudspeaker) , minimize the volume - hope it helps :) -- jesselle hannah ancheta
这个答案有帮助吗?
得分 0
添加一条评论
My husband's MotoE acquired an echo. What removed it, was the erasing of his history, closing all his windows, which were endless, or so it seemed and then the echo was gone. I also turned off his cookies and did all I could to stop adds as well. Val Lee of "val lee weblog”
这个答案有帮助吗?
得分 0
添加一条评论
Solved echo problem. The battery on my galaxy s5 was slightly swollen, pushing the cover out. If you look at the back cover there is a gasket or seal whichever. The battery pushing out keeps it from sealing. So just get a new battery.
这个答案有帮助吗?
得分 0
添加一条评论
It's not the phone its the AT&T cell phone tower's I talked to AT&T a couple months ago and they had been doing maintenance on several towers around my area. So to all you trying to find out the answer I hope this will help you may need to call AT&T about your area. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
Absolutely, I find that if you reduce the volume on your earpiece to about 75%, your caller will no longer complain of hearing his/her own voice echoing. Try it and let me know what happens
这个答案有帮助吗?
得分 0
3条评论:
tweety 6720000...have hearing problem so that won't work..had galaxy phone with Fido as my server for 4 yrs..never had these problems..
完成的
I also experience it with my Samsung note 9..If i use an ear piece it stops. But without ear piece/phone, it continues pls any suggestions
完成的
If you read the information section under this video (the text part) it gives a lot of good ways to narrow in on what is causing the echo problem and ways to fix it starting with the least amount of work. https://www.youtube.com/watch?v=FkcxzmCP...
完成的
添加一条评论
添加你的答案
Wendy 将永远感激不已
浏览统计数据:
过去 24 小时: 21
过去 7 天: 204
过去 30 天: 888
总计 661,882
