The Makita JV0600 and JV0600K are variable speed top handle jigsaws, designed for cutting materials such as wood, steel, and aluminum, with a stroke length of 7/8" (23 mm) and a range of 500 - 3,100 strokes per minute.
Is this jigsaw clogged with debris? Can you clean off as much debris as possible then try a little WD-40 into the release lever and blade jaw? Some light rapping against the body with a mallet can help loosen dirt buildup with WD-40 loosening up a sticky mechanism.
由 F Dryer 完成的
