My right joy-con has stopped working.
To trouble shoot I replace the joy-con from an older Switch. Worked perfectly, but this Switch is the Scarlet and Violet Edition so I'd love to have the joy-con working again. Have you got any kits to fix it?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 31
The problem will need to be isolated before an appropriate part purchase is made- if necessary. What troubleshooting steps have you taken so far besides confirming that the Joy-Con itself is not working? Does it simply not connect, or is there no indication of function at all?
由 Stranger 完成的
@stranger001 I've tried a joy-con from my Switch and it works fine.
由 Morgadeth 完成的
@morgadeth If there's no function at all or any signs of life from the Joy-Con when connected (I assume) and another Joy-Con works when connected to the rail, this isolates the problem range to the Joy-Con your talking about. Do you have any experience with disassembling a Joy-Con? If you do or have comfort doing so, you might find success in further isolating the problem by taking it apart and swapping the rail from your good Joy-Con to the bad one and vice-versa. Testing both Joy-Con after this will tell you if the problem is to do with that component or not. If it IS a problem with the rail, a replacement can be purchased to replace the faulty unit. If it isn't, the problem may be something somewhere else along the board.
由 Stranger 完成的
It's fixed out of nowhere. I have no explanation for it. But thanks anyway. You offered sound advice.
由 Morgadeth 完成的
@morgadeth No problem. I'm glad it's working again.
由 Stranger 完成的
