跳转到主内容
Repair guides and disassembly information for Lenovo's thin and light ThinkPad X1 Carbon business laptops.
Replacing 1TB SSD with 2TB SSD - not being recognised
I have ThinkPad X1 Carbon 7th Gen laptop. I am trying to replace a 1 TB SSD by cloning it to a 2 TB SSD. The clone completes successfully but when I install it I get a message that “A required device isn’t connected or can’t be accessed”. It reports “Inaccessible Boot Device”. I have tried various procedures recommended using a Windows 11 recovery usb drive, but to no avail. Has anyone experienced a similar problem, and if so, do they have any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
10条评论
Hi @mjkalba,
Is the SSD shown as being detected in the BIOS storage drive menus?
If not it may be a faulty drive or not connected correctly.
If it is then something went wrong when it was cloned
完成的
It is detected by thw BIOS. It can be accessed from Command Prompt mode in the Windows Recovery environment and by other tools recovery medir.
完成的
@mjkalba
Just verifying that you cloned it using cloning software and not just copied over to it from the original drive?
完成的
Cloned with Partition Magic, Macrium Reflect, and Aomei Backupper Pro. Same result with each tool..
完成的
@mjkalba
Have you checked that the cloned disc is set to "active" as shown in this link?
完成的
显示更多的5条评论
添加一条评论
2个答案
已选择的解决方案
In the end I bit the bullet and did a clean install of Windows 11. 🙁
Fortunately this is a laptop I use for gaming, so it was not full of apps and will not take too long to bring bank to its original state.
这个答案有帮助吗?
得分 0
添加一条评论
Did you move files over to the new SSD? Did you have bitlocker on the old SSD?
这个答案有帮助吗?
得分 0
1条评论:
Yes regarding the files, it was a complete clone, and no to bitlocker.
完成的
添加一条评论
添加你的答案
mjkalba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 239
