跳转到主内容
加入维修社区 - 创建账户
第二代 Integra 于 1989 年 4 月推出。在这一代车型中,JDM 版本的 Integra DA 系列搭载了本田制造的首批 VTEC 发动机之一。
I have no spark and no fuel pump prime
Car had bad wiring before and figuring it all out. Main relay was tested= good, fuses were tested= good, fuel pump was tested=good, the distributor is brand new along with the spark plugs and wires. Grounds are good to the battery terminal/transmission , thermostat housing, and valve cover. Car dash lights come on and car cranks. Check engine light stays on, I get no codes thrown when tried to flash for codes.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Would that be the same for a 93? Sorry just making sure
由完成的
@oniichanz
Yes is is for years 1990-1993
由完成的
添加一条评论
2个答案
最有帮助的答案
Hi @oniichanz
Here are some images from the 1990 Acura Integra repair manual showing the ignition circuit and the fuel pump circuit, that may help.
(click on image)
这个答案有帮助吗?
得分 2
添加一条评论
Since you have no spark and no fuel-pump prime, I’d check the PGM-FI main relay, power supply, and wiring first. A wiring fault could explain both problems at the same time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Onii Chanz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 29
过去 30 天: 50
总计 649
