MacBook requires SMC reset if not plugged in for a few days
I have a 13” Retina Display Early 2015 MacBook Pro running MacOS Monterey. It saw fair usage in its early life then went complete unused for a couple years and then heavy usage within the last year or two. The battery failed and would not hold charge. I replaced the battery with an iFixIt battery and it was revived.
The current problem: if left unplugged for a few days the MacBook will not power on and will require a power cycle while connected to a charger or SMC reset. When it comes back it still has a reasonable battery charge (80-95%). All battery health indicators in coconut battery appear to be in line and the battery charges and retains charge as expected.
Any idea what’s going on here and if it’s indicative of a bigger problem? It is not the biggest deal to have to keep resetting it but I am not the primary user so I’d like to fix/prevent it if possible.
Update (10/05/23)
Thanks for the response Dan,
Here is a screenshot from coconut battery
When did you replace the battery?
由 Dan 完成的
The battery was replaced in early august. Almost two months ago. The issue first happened about two or three weeks ago and has happened again yesterday.
由 jtb 完成的
