跳转到主内容
speakers (both)- hardware not working- iPhone 12 mini
Both speakers (and calls obviously)... hardware not working at all on iphone 12 mini. Used phone looks-as new, 99% battery health, with no physical or water damage etc. Made the mistake of buying (in person) used without even considering this kind of hardware/speaker issue before handing over $. Screwed up scammer/seller, oh well, another "cheap life lesson" in the grand scheme of things.
Tried resets including full factory reset, ios update, and any/all relevant settings adjustments etc.
Tested with diagnostic app such as phonedoctor pro which also shows both as failing/hardware issues.
Since the speakers are physically located in different locations of the phone and not (likely/seemingly in my perspective) related to one single loose connector or broken single piece of hardware - what are my chances of being able to fix it as an experienced DIY parts swapper?..
ANY input, experiences, anecdotes or specific advice would be greatly appreciated! Anywhere to look once I open it up, and/or known failed components that could cause all this? Once I solder in the new "loud speaker" with the regular one happen to come back to life. Should I expect to replace both. Thanks in advance!
Note; the iphone 12 speaker recall/campaign does not apply to the 12 mini. Note: either way, this phone is over a year old since first sold so even if it were a 12 not mini, it wouldn't have qualified anyway. I'm looking for repair help not advice to send it in etc.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would expect to replace both speakers. Just be careful and take your time. Use a hair dryer or heat gun to heat up the adhesive around the screen, use some isopropyl alcohol, a suction cup, guitar picks, and with a little patience, that screen will come off.
You could use the anti-clamp which you can order here: Clampy - Anti-Clamp
Or you could just buy the regular suction cup: Suction Handle
Suction Handle图片
产品
Suction Handle
$2.99
Clampy - Anti-Clamp图片
产品
Clampy - Anti-Clamp
$24.95
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
albert einsteen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 216
