跳转到主内容
Repair guides, disassembly information, support, and troubleshooting for Corsair gaming headsets.
25 个问题 查看全部
Corsair HS80 USB c not charging
Is there any way i can repair the USB charger for my headset? I believe the internal portion of the USB c is damaged or broken off. A charger no longer holds inside and even when I hold it in, it does not make connection.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Could you post a picture of the issue? Do you need plug in or connector fixed? As far as i know its not really difficult to replace it on this model. Google shows that on this model its separate board for charge in connector so you could easly order replacement and just replace it (plug and play). Otherwise if you dont have any soldering skills or equipement, it could be quite difficult.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
skipopidid 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 36
总计 300
