跳转到主内容
Why is my laptop not charging
When I plug in my the windows battery sign indicates that the laptop is plugged. The laptop itself doesn't charge, the charging brick led lights blue which means it is charging but I do have to say that the brick itself the tip is "slightly" damaged. So what should I do to fix the problem without just buying a new brick.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @mokachockachino
Connect a voltmeter between the inner and the outer connections on the barrel connector plug on the output cable of the charger and check if it shows 19.5V DC.
If it does flex the cable where it leaves the charger case and also where it enters the cable plug and make sure that it remains steady.
If it doesn't it could be a damaged plug connection or fractured cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Moka Chockachino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 90
