跳转到主内容
Google Pixel 7 的維修以及拆解資訊。此機型於2022年10月發表,有 GVU6C 及 GQML3 兩種型號。
30 个问题 查看全部
Where can I find a replacement motherboard?
My Google Pixel 7 does not charge or turn on. I took it to Asurion, who said the motherboard short circuited and would need a motherboard replacement. I'm much more concerned about recovering the data on the device than getting it back up and running.
A couple prominent data recovery companies have said that I need to replace the motherboard reball stencils, but replacement motherboards were not available.
I contacted Google tech support, who said that while they're not able to directly provide motherboards, I might be able to find a replacement motherboard from ifixit. However, ifixit said they do not carry Pixel 7 motherboards.
I would appreciate any help you can provide to find legit Pixel 7 motherboards.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
If your end goal is getting the data back, a new motherboard will not help you because the motherboard is the component where all the data is stored. So if you replace it, you'll only have the data that was on that board.
They said you need to "motherboard reball stencils?" I'm trying to figure out what they may have meant by that. Perhaps they didn't have the correct stencil for the job, or they needed components they couldn't find? Did they tell you exactly what the problem was?
这个答案有帮助吗?
得分 1
3条评论:
Yes, Salvage Data (data recovery company) diagnosed the phone and said they needed "motherboard reball stencils", and if that part wasn't available, they could take them off a new motherboard to fix my phone and preserve the data.
Asurion previously diagnosed the phone as having a short in the motherboard, with resulting heat damage.
完成的
@peterj616 I think I get it. They need stencils and particular components so they can repair yours. That makes much more sense. In that case, probably a site like e-bay will be your best bet. You don't necessarily even need that board, or the phone to work entirely, just the parts they need to harvest from it.
完成的
@flannelist thanks for your help!
完成的
添加一条评论
I’m sorry to hear that your Google Pixel 7 does not charge or turn on, and that you need to recover the data on the device. Finding a replacement motherboard for the Pixel 7 can be challenging, as it is a relatively new and rare model. However, there are some possible sources you can try:
  • You can check online marketplaces such as eBay or AliExpress for sellers who offer Pixel 7 motherboards or parts. However, you should be careful and verify the authenticity and quality of the products before buying them, as some sellers may sell fake or defective items. You should also check the seller’s ratings, reviews, and return policy.
  • You can look for local repair shops or technicians who specialize in Google Pixel phones or Android devices. They may have access to Pixel 7 motherboards or parts, or they may be able to repair your existing motherboard. You can use Google Maps or Yelp to search for nearby repair services and read their reviews and ratings. You should also contact them and ask for a quote and a warranty before proceeding with the repair.
  • You can contact Google directly and ask for a replacement device under warranty or for a fee. This may be the most reliable and secure option, as you will get a genuine and functional Pixel 7 device from Google. However, this may also be the most expensive option, and you may lose your data if you cannot transfer it from your old device. You can contact Google support from this link and follow the instructions.
I hope these suggestions help you find a replacement motherboard for your Pixel 7. If you have any questions or need more assistance, please let me know. 😊
这个答案有帮助吗?
得分 0
添加一条评论
I have mother board of Google pixel 7a
这个答案有帮助吗?
得分 0
1条评论:
Is it working condition, any issue ,can we use directly just by replacing the older one bcz it's dead
完成的
添加一条评论
添加你的答案
Peter J 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 54
总计 449
