跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1366 个问题 查看全部
Connect to Samsung tv
How can I connect to smart tv
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
To connect your iPhone 7 Plus to a Samsung TV, you can use either of the following methods:
  1. Wirelessly: Ensure that both the iPhone and TV are on the same Wi-Fi connection. Launch the Samsung SmartView app.(which you may have to download on your phone) It will ask you to enter the code that appears on your Samsung Smart TV screen. Enter the pin, and the device should automatically connect to your TV.
  2. Wired: Connect your iPhone to your Samsung TV with an HDMI cable to achieve the same effect. You will need a Lightning Digital AV Adapter and an HDMI cable for this method. Plug one end of the HDMI cable into your TV and the other end of it into the Lightning Digital AV adapter. Then, plug the AV adapter into your iPhone.
I hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samson Amdebrehan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 56
