跳转到主内容
加入维修社区 - 创建账户
To Remove battery adhesive
Can I use hand sanitizer to remove the battery adhesive other than isopropyl alcohol?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @z9ujn6g5y5rbz5r
It is best not to.
Isopropyl Alcohol 99%+ leaves no conductive residues and also evaporates quickly.
Hand sanitizer is composed of a mixture of alcohol (either Ethanol or Isopropyl) plus other ingredients (they vary depending on the manufacturer) and they may leave conductive residues unless thoroughly cleaned away, which could be risky depending on what was then used to clean any residues off.
My view is that it's best to use the IPA 99%+ as a 1 step process. Apply a bit at a time, gently remove some of the adhesive before the IPA evaporates and so on until the adhesive is all gone. Job done.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ı̣ɯı̣ʞɥ 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 294
