跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
It keeps randomly shutting off?
My pc keeps randomly shutting off. I did move at the beginning of the year, and though I was extremely careful with it, I do believe something moved out of place. I’m not knowledgeable enough with pcs to try and pry it open to fix it myself. Can somebody help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
temps?
is power button okay?
is the case controls secure on the mobo?
reseat all possible components ram, graphics card etc
这个答案有帮助吗?
得分 0
2条评论:
If you mean temperature, that shouldn’t be an issue
The power button is fine
Don’t really know what that means, but judging by context, it sounds like I’d have you open up my pc, which I haven’t done yet, so I don’t know
I could give that a shot I’d just have to figure out how
完成的
@raven12213 the temps would matter as if too hot it will shut down to prevent overheating and what i mean by the 3rd one is the cable going from you case secure on the motherboard and also if you have not opened it its a prebuild not a custom
完成的
添加一条评论
添加你的答案
Raven 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 63
