Frigidaire upright freezer stops maintaining temp after ~6 month
FFFU20F2VW upright freezer works well for about 6m then won’t maintain temp. Not overly iced up and fan still spins freely. Replaced heating element. Ran diagnostic test and everything seems to be working correctly. After unplugging and defrosting the unit it will run fine for about 6 months before the internal temp again begins to rise.
2条评论
Hi @jackd90504,
You said after unplugging and defrosting that it works again, how much ice was on the evap unit?
Did you have to defrost it to make it work correctly again?
How high does the temp get to when it stops maintaining the temp?
Is the compressor still running when the temp goes up or has it stopped and will it only restart if you reset the refrigerator by disconnecting/reconnecting the power?
由 jayeff 完成的
There was some ice build up but nothing excessive and the fan was still able to spin freely.
The temp continued to rise and it was no longer cooling. The compressor would try to kick on but wouldn’t fully turn over.
Honestly, I never tried disconnecting then reconnecting the power instead, I always unplugged it and allowed it to defrost before trying to figure out the problem.
由 Jack D 完成的
