跳转到主内容
加入维修社区 - 创建账户
Coffee brewmaster released in 2013. The Keurig K40 is a k-cup compatible coffee maker.
Keurig “lights of death blinking.” Pump stopped working.
After doing research, I’ve come to the conclusion the pump may be shot; but just looking for confirmation. Turned it on this morning, pump went to pull water, acted slower than normal. Did the whole “put out half cup for a cup” thing. Tried one more time and the pump finally stopped. Now it won’t do anything when turned on. I left it for a minute or two, then the “Add Water, Heating, and Medium Cup” lights came on…I’ve checked the filters, check valve, needles, etc. Everything seems to flow the way it should. Saw a “method” that said to press and hold the Med cup button while everything is blinking and then the system would purge itself (or at least that’s what it sounds like it does), but all that happens when I do that is kill those lights and turn the power light back on (it’s off while the others are blinking). Is there anything else that can be done?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I had this problem. Different model. It was the pump and when I lifted it a little it would work. I ended up putting a piece of Lego under the pump and it has been working for 8 months
这个答案有帮助吗?
得分 1
1条评论:
Lifted what? The whole coffee maker? How did you lift the “pump” and how did you find it?
完成的
添加一条评论
Take it back to the store that you bought it from, we’re on our third one, but that fix works ever time
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joshua Humeston 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 57
过去 30 天: 286
总计 6,018
