跳转到主内容
Connection to uppercase not covered in guides.
Step 10 of the guides to remove upper case doesn't cover how to disconnect a small, short wire connecting the upper and lower cases on the left hand side. This wire 'appears' to be coming from the headphone jack (difficult to tell) and going to some unknown black element covering the speaker grill. I stopped and reassemble my laptop till I figure out what the wire is and how to disconnect it properly.
Has anyone seen this connection in their repair processes, knows what it and how to disconnect/reconnect it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I believe that you are describing the airport antenna connecting wire. It may not be tucked away where it properly belongs along the side of the logic board, and should not be not connected to the top case. There are small "snaps" (see detail step 11) on the ends of the wire that connect it to the card. They pop UP easily.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
papageo09 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 359
