跳转到主内容
加入维修社区 - 创建账户
Introduced in September 2004 and replaced with a version in 2010. The following model numbers apply: ZA11S, ZC71S, ZC11S, ZD11S, ZC21S, ZD21S, ZC31S.
swift one door is not getting auto locked
Only three doors are getting auto lock, one remain unlocked
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Hi @vinod61596,
What is the year model of the vehicle and which door is the door lock not working correctly?
完成的
2012 swift , back door not opening
完成的
A/c compressor notworking
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @vinod61596
Bit confused as you first said the door is not auto locking and then later you commented that the door is not opening, which is it?
Either way if you meant that the door power lock doesn't lock or doesn't unlock, but you can still manually open the door from the inside, then it could be a faulty power door lock actuator or a wiring problem from the body control module (BCM) to the door lock actuator.
Here's an image showing the wiring diagram for the power door locks.
Here's a video that shows how to remove the rear door panel so that access to the wiring in the door and also the door lock power actuator is possible.
(click on image)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
VINOD 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 26
过去 30 天: 71
总计 1,707
