跳转到主内容
发布于9月16日,苹果公司的 "小型 "旗舰智能手机,其拥有6.1英寸ProMotion OLED,三镜头后置摄像头系统,5G,以及围绕前置摄像头和顶部传感器新设计的 "灵动岛"。iPhone 13 Pro的继承者。
25 个问题 查看全部
Swapping 14 pro max logic board into 14 pro body
Hey, anyone managed to swap 14 pro max logic board into 14 pro body? Looks like both logic boards are of same size and they are swappable. Any long term issues ? Pls help, I have a spare body of 14 pro and logic board of 14 pro max I want to swap to .
Update (09/27/23)
I have attached the side by side image @dadibrokeit
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I haven't opened up either of the two phones you've mentioned, but I can tell you this, that it's highly unlikely to work. The thing is, each logic board is custom designed for the phone it's in and the available space inside heavily determines the shape and size of the board and the placement of the connectors.
So far there have been no iPhones that have had compatible logic boards, and I see no reason to believe the 14 Pro series is any different. Not one single previous version of a Max or Plus model's board has been interchangeable with it's normal size sibling so it's unlikely the 14 will be either.
As I said, this is far from authoritative since I haven't held either board in hand, but based on Apple's history I feel confident stating that they won't interchange. I could be wrong and I'd be really interested to hear if I am, but I'm betting they won't fit.
这个答案有帮助吗?
得分 1
6条评论:
No , both logic boards are exactly same size and I even tried swapping it , but I want to know about any long term problems
完成的
@idgaf5 That is interesting, Mani; it's certainly a first for Apple. One problem is that Apple keeps all the information on internal sensors and attached components to itself so there's no way of knowing if everything is going to match up. On one hand it would make sense to design one motherboard that can fit two phones, but on the other hand they've never done that before.
If they're physically the same, then the next obstacle would be the placement of the connectors. If they move even one of them then something isn't going to fit.
Can you take side by side pictures of the two motherboards so we can look them over?
完成的
Attached the picture above
完成的
@Mani did you manage to try swapping the logical board of 14 pro to 14 promax? What is the result?
完成的
It worked well for one time from then on , screen is shrinking if i put 14 pro inside 14 pro max body and lcd. 😅
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Mani 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 137
总计 913
