跳转到主内容
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
20 个问题 查看全部
My bottom screen keeps scrolling to the side.
Anytime I try to use my dsi, it's like I'm pressing down on the right d-pad button. I've bought a new rubber pad, as well as a new d-pad board. I installed both of them, it worked for about a week, and now the problem popped up again. What could the problem be? Could it be something in the motherboard? Thank you in advance!!! :D (I would also like to add that there's no problem with the screen, I've done multiple tests, and it works perfectly fine)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
It could be something with the motherboard, or just an unlucky replacement d-pad board. You can double check the connectors to make sure they're not loose or broken.
这个答案有帮助吗?
得分 0
3条评论:
Thanks for a quick response! I disconnected the orange strip (not sure what it's called exactly) from both the pad, as well as the motherboard. It worked for a minute, but now the same problem returned. Would you happen to have any other possible solutions?
完成的
@travhuber10 try cleaning the connections with isopropyl alcohol
完成的
I'll try that! thank you!
完成的
添加一条评论
添加你的答案
travhuber10 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 56
