跳转到主内容
Rechargeable batteries not charging
I found an old Kodak Easyshare Z712 IS camera. It came with an in-package kodak rechargeable battery supply. I put the battery in and was able to take pictures for about 20 minutes before they died. I purchased a charger for the camera on ebay. The camera will run with the charger plugged in, but when it is removed the camera turns off. The camera will run on the charger even if the battery pack is removed. I also tried normal AA batteries and the camera will run on those. The charger does not seem to be charging the batteries, is there anything I can do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If you have a multimeter try to measure the + and - poles of the charger when you hace it plugged in. If the charger is good, you just need to replace the batteries
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mora 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 210
