跳转到主内容
The Land Rover Defender (initially called the Land Rover Ninety and Land Rover One Ten) is a British four-wheel drive off-road vehicle developed from the original Land Rover Series launched in June 1948.
5 个问题 查看全部
Noise when clutch pedal is depress
Landrover defender 130 td5 after i have replace the clutch kit and thrustbearing when i depress the clutch pedal there is a noise sound like gears running with out oil but with the clutch pedal still depressed and selecting 2nd gear the noise go away but when i select any other gears the noise comes back even when in neutral but when i release the clutch pedal the noise is gone can it be something in the gearbox or the spigot bush that cause that noise. Thanks Max.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Without more info on what kind of clutch system you have I would have to say you probably need to bleed the clutch system at the slave cylinder
这个答案有帮助吗?
得分 0
1条评论:
I have fitted a new clutch kit and thrustbearing a new clutch master cylinder and a new clutch slave cylinder the clutch have been bled about 3 times already but the noise stay there.
完成的
添加一条评论
添加你的答案
Max IRMSCHER 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 129
