Is my keyboard connector broken? Part 518S0752
I've replaced the keyboard on this but rows of keys would stop working but then would work again. The problem is slowly getting worse. I've tried replacing the keyboard yet again and the same issue is showing up.
I suspect it's the keyboard connector, part # 518S0752. https://www.injuredgadgets.com/5-pack-ke...
The plastic lock tab on it is broken. I assumed it was just for holding the ribbon cable in place, or does it actually put pressure on the ribbon to make contact with the pins on the keyboard connector?
The latter is what I'm guessing happens and why my keyboard still won't work properly despite two replacement keyboards...
The only other thing I can think of is maybe the ribbon cable is breaking from the bend pressure from the touchpad since it needs to fold a bit for the touchpad to go back on. Is there a way to use a multimeter to rule out the keyboard connector or anything?
