跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
问题已关闭
Power button bracket broken.
Hi,
an ipod touch 4 has been dropped and screen and back cover have been replaced but the power button isnt working. The small metal plate which sits behind it has broken and 1 of the screw holes is now missing as a result of this. I think this is the problem because the volume buttons still work and i dont think its the ribbon. Problem is I cnt seem to be able to get a replacement bracket from anywhere. can anyone help please?
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
I also need that part for my son's iPod, and haven't been at all successful in finding a source. I'll probably end up trying to lay my hands on a broken unit to use as a parts donor. I've been looking for a while.
完成的
Greg, I'm in the same position - metal power button bracket broken on iTouch 4th gen. If you get an answer for this as to where to buy, please let me know!
完成的
Is this what we are looking for?!
http://saraoutlet.com/replacement-spare-...
i've got the same problem with my iphone 4.
完成的
添加一条评论
1个答案
已选择的解决方案
That is a tricky one. That ribbon is very fragile and could have been torn even slightly during the drop. I have had torn ribbons that only effected the lock button and not the volume button depending on where the damage is. Look very closely at the ribbon right under the button with a magnifying glass or something, you might find a little rip. It could be the bracket like you were saying but from what I have seen you would have had to really drop the ipod to hurt it. It might be worth a shot if you can find a one for parts, I have never seen that part for sale. Best of luck!
这个答案有帮助吗?
得分 0
1条评论:
Hi thanks for that, I cant see any damage to the cable but i've ordered a new 1 which should be here today, ill fit it and see what happens. Also i'll let everyone know if I find where to get the brackets from.
Cheers
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,834
