跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
MacBook air pop and dead but no obvious culprit - help please
My daughter’s 2017 Macbook Air made a clear popping noise, no smoke, and then died. No power up or response to SMC or PRAM key sequences. I tried to find a blown component on motherboard or power connector mini-board but everything looks fine. Any suggestions before we head over to Apple store? I have uploaded pictures - thanks!
Pictures after cleaning
Passive components seem ok, I wonder if an integrated circuit can fail with a pop that doesn’t show…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
While hard to tell I see a questionable area on the backside of the board just below the MLB label just below the string of resistors and capacitors there are a few transistors give the board a wipe to clean off the dust and take a fresh image of this area again.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for looking Dan. I’ll update the post with better pictures. Unfortunately I had to take Humpty Dumpty apart again for the cleaning and new pics and I ended up breaking off one of the wi-fi connector leads so I’ll post a new question for the new problem I created!
完成的
添加一条评论
添加你的答案
Daniel R 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 59
