跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Possible logic board issues
I have this iPhone 8 that I got for free but it was iCloud locked. I bought a logic board from eBay and it worked great. I got settled in and used it when I realized that I forgot to put the connector brackets back in. I powered it off, opened it and one of the screen connectors came disconnected while the battery was still plugged in. I think it was the home button cable but not sure. I put it back together, turned it on, and nothing. It takes charge but won’t turn on, make noise or display anything. I’m very worried I may have just destroyed a new board. Any advice is appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
On the older iPhones that contained an LCD display, it was not at all unusual to blow out the backlight circuit on the display if you plugged and unplugged it with the battery still connected, which is what may have have happened to you.
Try a couple more things to see if that's what's happened. First, shine a flashlight up against the screen in a darkened room and see if you can make out an image. If so, that's a dead backlight and replacing the screen should fix it.
Next, let's find out if the phone is indeed awake and you're just not seeing it. Flip the ring/silent switch on the side and see if you get the typical vibration when you do it. Does it vibrate when you plug and unplug the charger? Is it recognized when you plug it into a computer? If any of those things work then once again it's likely you've killed the screen and replacing it will probably get you going again.
Give that stuff a try then come on back and let us know what you find and we'll see what your next step should be.
这个答案有帮助吗?
得分 3
7条评论:
I tried a flashlight on the screen, mute switch, charging, iTunes, and nothing happened. I’m thinking it’s a board issue but I’m hoping it’s something else
完成的
@epicgamera94741 Curious about what you meant when you said it "takes charge" in your question. Does the screen give some indication that it's charging? Have you tried a wireless charger?
完成的
Yes I used a wireless charger and the light would turn green when I put the phone on
完成的
Ouch, well, something has definitely gone wrong there. Do you still have the old logic board that could be replaced to see if the phone comes up with it? That would tell you fairly definitely if it's a logic board issue or not.
完成的
Ok I put the old board in and it turned on just fine. I think I just have to figure out the iCloud lock at this point and remove it
完成的
显示更多的2条评论
添加一条评论
添加你的答案
EpicGamerAlertYT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 62
