跳转到主内容
Repair and disassembly information for Samsung's Galaxy A13 Android smartphone, released in March of 2022.
96 个问题 查看全部
One UI 5.1 and battery life
Since the last update, my battery gets drained very quickly. I have all of the settings on to optimize. I close apps. I go on local wifi. Is there anything else I can do to make it last through my work day? It used to be 70 - 80% at end of day. Now it is 20 -30%.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try shutting down all apps and putting on airplane mode to see if it still depletes fast.
If so, it is a battery/phone issue.
If not, turn off airplane mode and try again.
If so, shut down wifi and try again.
If not, open one app at a time to find the power hog.
You need to eliminate the possibilities.
这个答案有帮助吗?
得分 0
1条评论:
I need to run it with 5G/wifi, so I can't leave it in airplane mode or with wifi off. Most times when I look in the battery usage the One UI is the largest hog. Most of my apps, I do not have set to run in the background.
完成的
添加一条评论
添加你的答案
wrecky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 68
