跳转到主内容
Repair information for the 4th Generation iPod shuffle. Released in September of 2010. Model number: A1373.
31 个问题 查看全部
Bad connection with the 3.5 jack
I have a bad connection with the 3.5 jack on my ipod shuffle 4th G.
Tested with several headphones and speakers, I need to hold the jack to get sound.
Can I re-establish contact without dismantling the device?
I've already tried blowing out the dust and removing it with a needle.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
About all that's left to do would be to maybe try flushing it out with 90% or higher concentration isopropyl (rubbing) alcohol then blow it clean with a can of compressed air. If that fails then yeah, you're down to opening up the Shuffle and removing the logic board.
iPod Shuffle 4th Generation Logic Board Assembly Replacement - iFixit Repair Guide
Once the board is out, you might be able to see if there's something wrong with it. Unfortunately, I wasn't able to find any information on how to go about replacing the headphone jack so I'm afraid that's something you'd have to figure out for yourself. The part itself is readily available online but I can't tell just from pictures how it's attached to the logic board. You may have to solder it, or perhaps not. Here's an example of where you can buy the part; there are many more online.
Headphone Audio Jack Hold Switch Module Repair Part for iPod 4th Gen. iPod Color Photo 20GB 30GB 40GB 60GB - AliExpress
If you decide to tackle the replacement, be sure to take lots of pictures, then you can use them to author your own guide and help out the iFixit community, who will appreciate it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Clément L 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 110
