Phone is not switch on
Phone is not switch on?
Try using the original adapter to charge or another that supports the same voltage and ampere. Another solution is to disassemble the phone, disconnect everything from the main board and then reconnect.
这个答案有帮助吗?
My phone stuked when i force reboot it it works and stucks every time now my phone is not turning on
Trying doing a hard reset with the charger plugged into the device. You can do this by holding + Power button + Volume down button and after 15 seconds press the power button and turn it on.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 35
总计 831
Hi, please describe the problem clearly
由 Electronics Boy 完成的
由 danny singh 完成的
Phon is not on
由 saikat biswas 完成的
When phone switching on showing only logo , 4 - 5 day after it will not switching on.
由 HDMA Movies 完成的
