跳转到主内容
Repair and disassembly information for the Powerbeats Pro true-wireless earbuds. Released in May of 2019. Model number: MV6Y2LL/A, MV702LL/A, A2047.
11 个问题 查看全部
Why are my power beats dying within 10-15 minutes after a full charge
My power beats are not staying on very long at all but they say they’re fully charged. Why are they dying within 10 minutes?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @harley1779
Most probably the batteries are failing and need to be replaced. Even rechargeable batteries have a lifespan.
Here's a teardown video that may help.
At 1:30 minutes into the video the battery is shown.
Unfortunately it is too unclear when zoomed in to make out the model number of the battery. You may have better luck.
If you decide to replace the battery, search online for the model number on the battery and get the type that has "solder tabs" attached i.e. (insert model number) with solder tabs, so as to make it easier to reconnect to the motherboard.
You need to apply too much heat when trying to solder batteries without them and this can damage the battery.
Also check the polarity before disconnecting the battery (or take pictures) so that you connect the replacement battery the correct way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 36
