跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
iPhone not recognize the lightning adaptor
Iphone did not recognize the lightning adaptor which I use for headphoes asa well as for charging , It recognize it when I use it for charging but not recognize when I use earphones, To use earphones I have to put charger in it for one time and it start working but when I remove it and again put it back in phone its not work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would imagine you are talking about a Qi charger and not an adapter as cables do not have preference as for the device. If the same “not recognizing the other device” issue happens both with headphones as with the phone it might be a fault in the charger.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
solo king 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 57
