跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
What voltage should be supplied to the battery when charging?
I have an iPhone 5 that won't turn on, and I'm trying to figure out why. It won't turn on with or without the battery connected.
When I run a multimeter over the connections to the battery on the logic board whilst charging, it varies between 1.2v and 1.3v. That's pretty low, and even after charging overnight (approx. 8 hrs) the battery did not hold a charge so I'm planning on replacing the dock connector and battery. Before I do that I just wanted to check, what should be the expected voltage being supplied to the battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The lithium battery in the phone has a nominal voltage of 3.7 v. But that's an average. Depending on the % charge, the voltage can be between 3.2volts ( low charge) to 4.2 volts ( full charge). So I agree, your measurement of 1.2 v is very low.
I'd say you need a new battery, as you planned.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
hugh19s 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 25
