跳转到主内容
Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
Pendrive does not showing in drive
I have hp 16gb pendrive. When I put in my laptop, the pendrive is not showing in drive , when i tried to open it the computer give me msg " insert a disk" ,also tried to put it in tv but same it was not opened,
how can I open it ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@dharapatel45173 What operating system are you running (e.g. Windows 10)?
完成的
operating system is Windows 10
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @dharapatel1 , sounds like it could be a failed drive unfortunately! This is a pretty common failure mode when the NAND flash stops being able to be written to. The controller still shows up, but its no longer able to communicate with the NAND memory. It might be time for a new drive. Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dhara Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 179
