Display driver has stopped and recovered
The screen will be while log on.
The error message "Display driver has stopped and recovered" means that the graphics driver on your computer has crashed and then recovered. This can happen for a number of reasons, such as:
If you are seeing this error message, there are a few things you can try to fix it:
Run a diagnostic tool
To run a diagnostic tool, you will need to download and install the program from the manufacturer's website. Once the program is installed, launch it and follow the on-screen instructions to test your computer hardware.
If the diagnostic tool finds any problems with your computer hardware, it will display an error message. You can then use the information from the error message to troubleshoot the problem or replace the faulty hardware.
Here are some examples of diagnostic tools:
It is important to note that diagnostic tools can put a lot of stress on your computer hardware. It is important to monitor your computer's temperature while running a diagnostic tool and to stop the test if your computer starts to overheat.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 72
