跳转到主内容
Replaced logic board, now getting blinking question mark Folder
Pretty much what it says in the title, I replaced the logic board using the instruction guide and everything went as planned, but upon powering on, I see the blinking question mark folder.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
In your case the logic boards static PRAM data is looking for the drive it had before or if it’s a new logic board it’s not set.
Here you need to first leverage the startup disk control Option (⌥) from your keyboard to then manually select the drive, then after it has booted up go to your systems preferences to set the startup disk so it’s set.
Reference: Mac startup key combinations
这个答案有帮助吗?
得分 0
添加一条评论
usually an hdd issue
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
John Menna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 15
总计 44
