跳转到主内容
Airport card does not detect networks
This problem started after I reinstalled OS and while downloading the updates, the electricity supply went off and power was cut. The airport card shows 'yellow' light and tries to look for networks just for a second but does not detect any network. I have run extended hardware test and it did not show any hardware problem. What could be the problem and how to resolve it so that I can use wifi.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
First of all I would recommend creating a new network 'Location'. This can be done by following the instructions below;
Launch “System Preferences” from the Apple menu or Dock
Select the “Network” panel
Click on the “Location” pull down menu and choose “Edit Locations…”
Click on the + plus icon to add a new network location, give it a unique name, and click “Done”
This will create a new set of Networking settings.
We can also try trashing the Airport plist, this can be found in the following directory;
/Library/Preferences/System Configuration/
Delete com.apple.network.plist and com.apple.airport.preferences.plist
You may need to enable the Library since you are using OSX Lion, this can be done by typing the following command into the Terminal, found in the Utilities section,
chflags nohidden ~/Library/
Send this file to Desktop to keep it safe for now and then restart the Macbook. Now try to find your network.
Hope this helps,
这个答案有帮助吗?
得分 1
添加一条评论
Sorry for this big delay in replying as I was travelling. Sorry but nothing mentioned above works. I have snow leopard and not lion. OS 10.6.8. The service center says the problem is with airport card and display. How can that be possible? Can interruption in electricity supply damage the airport card and display??
这个答案有帮助吗?
得分 0
1条评论:
I don't know what they exactly mean. The only known connection between Airport and display is that the Airport antenna is soldered to the left display hinge (at least on my much older Macbook), and I once find one of the two antenna cables mangled out of wear and tear. Soldered it and started getting again a nice reception.
Have you tried ruling out software issues by booting up from an external drive with a clean install of OS X or in Windows 7, if you've got Boot Camp set up?
If it works, it's surely software. If it doesn't, and only if it doesn't, there [b]may[/b] be some problem with the Airport itself.
Just remember the phone support is instructed to deal just with "first aid", leaving the AASP all the heavy work.
So, before trying anything else, if you can, boot from a clean booting drive.
完成的
添加一条评论
添加你的答案
milind 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,259
