跳转到主内容
加入维修社区 - 创建账户
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
3DS won't turn on, but says the battery is at 100%
The power light won't turn on much, and when it *does*, it flickers. Most of the time it won't turn on at all unless it's on the charger. Rarely, the device will "turn on" and then a second or two after, it turns off.
The one time I have seen the device turn on fully before it shut itself off, the battery icon was full. Which is weird because it won't turn on most of the time/ at all if not plugged in
The charging light also flickers, and I know the charger works, I tested it on a different system.
I'm not sure if it matters but the 3ds is modded.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The battery may not be seated correctly, as the 3DS will still work on the charger with no battery inserted. You may want to replace the battery. I've attached the guide: 3DS Battery Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zuku Midoriya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 99
