跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
Battery not charging. New battery charged only once
Hi,
The battery on my MacBook (A1708 from 2016) stopped charging without apparent reason. In the menu it said "Connected to power adapter. Battery not charging". In the system preferences, battery status was labeled "healthy". I tried the original power adapter + cable and also an HP 65W power adapter. I tried both USB-C slots, without success. The MacBook eventually turned off and I could not turn it on anymore.
Then I installed a new battery from ifixit. With the new battery my MacBook turned on again, and I was able to charge it from 55% (after installing the new battery) to 100%. Then I used the laptop until the battery was completely drained for calibration. Now again my MacBook won't charge. Even after leaving it connected to the power adapter for several hours, the screen stays black and there's no sign of power.
What could be causing this? If the charging circuitry is broken, I'm surprised that I could charge the replacement battery one time, before it stopped working again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sadly it does sound like the charging control logic is messed up.
I’ve seen this quite a few times. Every time I slide the battery into my spare Fn system I can get it recharged enough to test. I install CoconutBattery to see what it tells me often I see an old battery or the sensors are not reporting properly.
As you don’t have a spare system to check things, you’ll need to seek help from an independent shop who has Mac circuit board repair skills.
I’ve replaced a few Renesas (formerly Intersil) ISL9239 battery charger chip which you can see here on Step 17 带功能键版本的 MacBook Pro 13寸 2016年末款拆解 in the second image.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
malte 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 92
