跳转到主内容
Find repair and more information about the Samsung RB195AB** refrigerator, a 2008 model with bottom freezer, door access, and features like automatic defrost and an anti-sweat heater switch. This page covers information for model numbers matching the pattern RB195AB**.
Samsung Model RB195ABBP display not working
The display on my Model RB195ABBP stopped functioning properly. The fridge works. However, the temperature for both the fridge and the freezer no longer display. Instead, I see two flashing blue short lines. I've tried unplugging and replugging as well as turning off the breaker for a few minutes with no succces. I have attached some photos and a video.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @nicjunior
There are no images attached to your question.
Looking at the schematic it may be a problem with either the display board, the cable connection (at either end) between the display board and the main control board or the main control board.
Are the temperatures in the refrigerator and freezer compartments OK? Place an appropriate thermometer in each compartment and check if the temps are approximately 39°F (3°- 4°C) refrigerator and 0°F (-18°C).
If is it determined that a "board" may be the problem, unfortunately I cannot find a parts list for the model that includes the boards, only some other parts for the model. Hopefully there may be a board number on the board itself. It may show as DA-97 ???????? but maybe not.
这个答案有帮助吗?
得分 2
2条评论:
Thank you, Jayesh, for your answer. I did upload some pictures. I'm not sure why they are not attached to my post.
In any case, I will try to locate where the display board is to get a parts number. Hopefully, replacing it is something that's easy enough for me to do.
完成的
Did you ever find solution for this... Have samme issue here
完成的
添加一条评论
添加你的答案
Nic Junior 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 464
